Machine Vision
Help with Get LCD ROI VI
Hey guys, this is my first time posting in the forum, so sorry in advance if I am doing something wrong.
The objective of my program is the following:
Given an image of a multimeter with all seven segments on, find the ROI of all individual digits so I can pass to the IMAQ Read LCD.
Some things you should know:
  • The program will run in different images of multimeters.
  • The multimeter with all 7 segments on will not be in a fixed position.
  • After the 7 segments image the following images will be in the same position.
  • I know I can draw the ROI to pass to the IMAQ Get LCD ROI VI but the objective is that the program can detect the ROI alone. Ideally I want to pass a constant big rectangle ROI that I know all digits of the multimeter will be. (see attacheds images).
Problems Found:
  • When passing a big photo like the one attached LabVIEW just crashes when using IMAQ Get LCD ROI VI. (Using a smaller images works)
  • The ROI I need to pass to the IMAQ Get LCD ROI VI needs to fit very well in the digits so it can work.
  • When the ROI passed to the IMAQ Get LCD ROI VI is not well fit it returns a error saying it's not a valid lcd image or ROI.
Is there a way to find the ROI Automatically to pass to the IMAQ Get LCD ROI VI ?
I have attached the images and the code,
Thanks in advance
(2,951 Views)
Hey lukasab,
Check this example and see if fits your needs.
Cheers,
Felipe Flores
Applications Engineer II
National Instruments Brazil
(2,901 Views)
That doesn't help me, but thanks anyway. The problem is finding the screen ROI from the multimeter.
(2,858 Views)
