Machine Vision
Camera file (.icd) for Mikrotron MC1362 camera; using with PCIe-1433 Full CL grabberboard
Hello!
I am trying to use Mikrotron MC1362 camera with PCIe-1433 frame grabber board. There is no camera file available on NI for this camera. I would like to know if anyone has already generated a file for this before and if they could share it?
Thank you.
(2,148 Views)
Hello gklrajan,
I am afraid the Mikrotron MC1362 is not NI supported.
This means you should modify the camera files but this is known for being quite tough.
You could ask your supplier to share a camera file you could use.
If you want to try generating it yourself:
http://sine.ni.com/nips/cds/view/p/lang/en/nid/14207
I hope someone will post a file for you:)
Have a nice day,
Armando
(2,121 Views)
I also found this topic that could help you a bit building your picture file if you chose this solution:
https://forums.ni.com/t5/Machine-Vision/Imaq-grab-with-MC1362-causing-crashes-when-program-allocates...
(2,118 Views)
