Machine Vision
Grabbed Image shown incorrect
Hi
I'm grabbing images with an CCD-Camera (single or continuous), but the image that is shown looks like it is 'duplicated' a few times and it moves horizontaly. I assume that the caturing sequence works fine (aquisition of images to buffer).
Taken images should be 8bit bitmaps.
I attached a screenshot of a simplified version of the labview 7.1 code and the images taken with labview and the original camera software
I hope you could help me
Overseer
(3,251 Views)
It looks like either the acquisition or image conversion is configured wrong.
If you were using an NI board, I might have some helpful suggestions, but I don't know anything about the board you are using.
I can only suggest that you double check all your inputs and outputs.
Bruce
Bruce Ammons
Ammons Engineering
(3,223 Views)
Hi Bruce
I'm not using an NI Board.
I use a CCD Cam called "BCi4-6600", which has a *.dll to acces the device.
I already triple (and quad) checked nearly everything and i'm still getting the wrong image.
I think that i'll have to write a c++ programm to check, if the dll works correctly...
(3,215 Views)
