09-06-2007 01:35 AM
I can communicate with Spyder 2 (DALSA - SG-10-01K40-10E) inline camera with 1024 pixels by using MAX software. The camera can be set in 8 or 12 bit mode. In 8 bit mode I can see only 512 pixels and saturation level of 255. In 12 bit mode I can see only 1024 pixels and saturation level of 255 instead 4096. When camera is saturated the histogram shows 255 and number of pixels approximately 1000 in 8 bit mode and 4096 and number of pixels approximately 1000 for 12 bit mode. This indicates that camera works according specification.
I would like to read row data (intensity of light captured by 1024 pixels expressed in integer numbers up to 4096) in One Shot mode. For that purpose I have modified Example: Grab an Attributes to display row data and to print data in the table. I am using NI_AALPro.Ivlib:Peak Detector.vi to set threshold, to find Peaks and locations. I have Vision Acquisition 8.2.1 software.
Your prompt response with recommendation and suggestions will be highly appreciated.
09-07-2007 02:11 PM
09-07-2007 04:37 PM
09-27-2007 10:33 AM
I am working with a Dalsa Spyder3 GigE Camera. Dalsa has sent me firmware upgrades, which I have applied to the camera. But now MAX will no longer work. I am getting an error that indicates a bad XML file. The document referred to in last post advises to run the Camera Validator. However, this Utility is no where to be found. I checked other PCs here at the lab that have NI-IMAQ installations (with older, non-GigE cameras), and none of them seem to have this CameraValidator.exe uitility. (Yes, I did a full search.) Is this an Add-On Tool?
Another related question: what should the exact file name of the XML file be?
09-28-2007 09:52 AM
10-02-2007 03:42 PM
10-02-2007 04:32 PM
10-02-2007 05:08 PM
10-02-2007 11:09 PM
Hi Gretchen,
Sorry, but Vision Acquisition 8.2.1 did not yet include the camera validator utility. It is included with Vision Acquisition 8.2.2 and later which you can download and install (it should work with your existing license). The utility makes use of features in the IMAQdx driver that are not present in earlier versions so the individual file posted previously will not work.
With regards to your XML error, can you tell me the exact error text you see? Can you try clearing your XML cache folder under C:\Program Files\National Instruments\IMAQdx\Data? Its possible with the firmware update you have an invalid file cached there.
Hope this helps,
Eric
10-03-2007 03:46 PM
Eric - thanks for your valuable information. I downloaded and installed 8.2.2, and Now, at last, I have cameravalidator - mystery solved. However, when I execute it, it vanishes as soon as I see "opening 'cam0'".
The exact error message:
IMAQ Error
Error 0xBFF6901D
Unable to load camera's XML file
I tried removing all XML files from the Data/XML folder, but neither the cameravalidator tool nor IMAQ work.
Gretchen
