Machine Vision
GigE camera attributes setting in MAX not working properly
I have the current setting which was working for a while then the following happened:
Setting:
  • 2 GigE cameras (The Imaging Source DFK 23GP031) each with TP-LINK TG-3468 PCIe Card with Ethernet Cat6 cables.
  • LabVIEW 2013.
  • LabWindows CVI 2013.
  • Vision Run-Time 2013.
  • NI-IMAQ 4.8.
  • NI-IMAQdx 4.3.
Issues:
  • I insist this setting worked just fine for a while (days).
  • Camera Attributes::Gain can be set while Grabing but when I Snap this value goes back to what seems to be a "Default" or "Auto".
  • I set Camera Attributes::Gain to Auto and the value that was fixed while Snapping in the previous point increases. (I do this several times and the increase it's the same: from 45 to 46 to 47).
  • Sometimes one of the cameras is't recognized (red "x" issue in https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YM6JCAW&l=en-US).
All the other attributes can be set normally. I installed the latest driver for my cameras and rebooted the adapters several times. None of these seems to work.
Also the cameras in the NI_IMAQdx Devices tab in NI MAX appears as the image shows, where I believe cam2 and cam3 refers to the same device, being cam3 the setting of the Ethernet parameters and cam2 the setting of the vision attributes of te camera  (I haven't seen any other cameras in the forums with that view)
I hope someone can help me. I have spent a lot of time into this going to endeless forums.
Thanks in advance,
Julian
Message 1 of 8
(5,862 Views)
Hello JulianC,
I believe is not a problem that you have two cameras with the same model, MAX and LabVIEW are going to recognize them as cam1 and cam3 without issues
Your IMAQ and IMAQdx verions are compatible with your LabVIEW version:
https://www.ni.com/en/support/documentation/compatibility/17/vision-acquisition-software-and-labview...
What operating system are you running?
Can you tell if when one of the cameras gets red x did the PCIe card disappear from the Windows Device manager (in case you are using windows)?
Have you try to change the atrributes from LabVIEW?
Randy @Rscd27@
Message 2 of 8
(5,837 Views)
Thanks Rscd27,
I was starting to update all my software from NI before you response. So far I could download VISA 15.0. It seems no compatibility issues should be present. Although, I have NI-IMAQ 4.8 installed and in the links you sent me the NI-IMAQ 4.8 does not appear. This is the current software I have installed on my PC (Windows 7 x64):
I have a Software Block in LabVIEW which sets all these attributes, and also doesn't work either. I only have NI MAX opened and the issue with this parameter is still there.
Message 3 of 8
(5,832 Views)
You have IMAQ 4.8 is listed there :manvery-happy: and IMAQdx is 4.3
Can you attach the VI or maybe a screenshot to see the code?
Randy @Rscd27@
Message 4 of 8
(5,823 Views)
Randy,
Ok. I have installed both MAX and VAS 2015 and the problem persists. My concern is that the attributes in the MAX are not working well. With that being said, if I'm not mistaken, the fact of making it work using LabVIEW or CVI is very unlikely to happen. Correct me if I'm wrong about this, but I don't see how. By the way, in LAbVIEW doesn't work either.
Hope you have something else that can help me.
Julian
Message 5 of 8
(5,801 Views)
Hello Julian,
Yeah if it does not work on MAX, maybe is not going to work on LabVIEW or CVI. However as you may know MAX has limited funcionality. That is why I will like to tes the code.
Warm Regards,
Randy Cespedes
Applications Engineering
www.ni.com/support
Randy @Rscd27@
Message 6 of 8
(5,798 Views)
Randy,
Trying to keep working on this and having updated to VISA 2015 and VAS 2015. The following error appears when I try to select a GigE camera and then the red "x" appears as shown in both images.
Message 7 of 8
(5,775 Views)
Hello Julian,
I believe that we can try to reset the MAX data base:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P8awSAC&l=en-US
Warm Regards,
Randy Cespedes
www.ni.com/support
Randy @Rscd27@
Message 8 of 8
(5,764 Views)
