Machine Vision
GT6600 monochrome camera: can LabVIEW work with 14 bit image
I'm using 14-bit pixel depth image in LabVIEW vision. Smees like Labview doesn't support 14 bit image. Is there any way to get arond this?
Thanks much!
(4,919 Views)
14 Bit images are treated as 16 Bit in VDM.
Values will be between 0 and 16385 for U16.
Machine Vision, Robotics, Embedded Systems, Surveillance
www.movimed.com - Custom Imaging Solutions
(4,911 Views)
Thanks!
That is for displaying image though. For other processing, seems like it is necessary to convert 14bit to 16bit image?
(4,890 Views)
@nkhoa wrote:
Thanks!
You are right!
(4,887 Views)
No. In the memory space, 14-bit data is already being treated as 16-bit. You will need to consider that not all VDM functions can work on data larger than 8-bit.
there would be no difference between a 14 and 16 bit image where no value is greater than 16385.
(4,882 Views)
