Machine Vision
Find highlighted character position
I am having problem in finding the highlighted character in the attached image. right now i am using a pattern matching technique to find the position of the rectangle(see fig). but this solution is not a perfect one (5% failure rate).
If somebody is having any idea then let me know. My final goal is to give the coordinates of the selected character to my OCR vi.
Thanks in advance,
-Suhas
Message Edited by Suhas on 08-29-2006 11:03 AM
(4,195 Views)
Suhas,
Do you expect the character to be at the same location relative to the "DELETE" text? Also, do you expect the orientation of the characters to be relatively horizontal?
Satish
(4,158 Views)
Suhas,
After looking at the image you attached, in this case geometric matching might be more effective than pattern matching.  While geometric and pattern matching are similar, geometric matching looks strictly at edges and shapes.  The highlighted E has a lot of good geometric qualities to it, which may help improve your failure rate.
Jason
(4,142 Views)
Hello Satish,
Any charachert from A to Z may be highlighted so the position is not fixed with respect to the "DELETE" text. The orientation of the character is always horizontal.
-Suhas
(4,099 Views)
Hello Jason,
Sorry but i forgot to mention that i am using Geometric pattern matching and the failure rate is with respect to that.
Any other suggetion or idea to detect the highlighted characher position?
-Suhas
(4,099 Views)
Suhas,
If the general locations of all the characters will always be the same, even though at times certain different characters will be highlighted, you could possibly used some simple edge detection to improve your accuracy.  Using the location of the "delete" text as a reference point for a coordinate system, you could look for edges along lines above the tops of the two rows of normal characters that would intersect the box around the highlighted character, returning edge locations.  These locations would reflect the position of the highlighted character.
Jason N
(4,044 Views)
