12-10-2009 11:02 AM
While playing with some settings in MAX probably I did something wrong, I guess I have broken the PAL.icd file ... Should I overwrite it, if so where to find it.
That is what I see, when in the properties of the channel I want to change it to PAL. Other types work just fine.
Solved! Go to Solution.
12-11-2009 06:16 AM
