Machine Vision
Extract annulus ROI and change to array
Hi Guys
I am trying to extract a small annulus portion of image and change the extracted image to array for processing. I only found the Imaq VIs that can only extract rectangular. Is there any way to extract annulus shape image and change the extracted  to array.
What I made the annulus region of interest is inner radius=0, angle=0 and end angle=0, which forms a circle.
(4,184 Views)
Try IMAQ Unwrap.  It converts an annulus to a rectangular image.  It is intended for OCR, but works fine for other things.
You might have a problem with a zero inner radius, because there is nothing there to unwrap.  You will get the same pixel stretched all the way across the bottom of your image.
Bruce
Bruce Ammons
Ammons Engineering
(4,179 Views)
