08-29-2013 07:55 AM
From the attached image,i need to extract(find) the features of the target object,in which the printer is the target object.
What are the target feature to be extracted ? and
how it can be extracted?
Thank you
08-29-2013 08:31 AM
Hi Madhubalan
You can get an idea from the following review article. (http://crcv.ucf.edu/papers/Object%20Tracking.pdf : Object detection part)
Chul Min
08-30-2013 06:59 AM - edited 08-30-2013 07:00 AM
how about using SIFT descriptors and homography. You need at least 4 matched keypoints to calculate the homography.
Please see the attached example (your image). You need to install OpenCV 2.4.6 (http://opencv.org/) and add the "C:\Program Files (x86)\OpenCV 2.4.6\opencv\build\x86\vc10\bin" to system path (see here: http://windowsitpro.com/systems-management/how-can-i-add-new-folder-my-system-path).
Then just run the example. Here is a screenshot of the result.
K
09-01-2013 04:46 AM
09-01-2013 06:22 AM
please see the following link for source code:
Scale-invariant feature transform source code&DLL
K
09-18-2013 05:33 AM - edited 09-18-2013 05:34 AM
Hi klemen,
for object detection using SIFT,i could able to detect the object by comparing the refrence image and the main image,
For the attached images i could not able to get the rectangular box to detect the object but i can get the matches.
Thank you
