Do you not get a pulse out with the example program either? I'm curious as to whether there is an issue with the pulse creation, or with the way it is set up in the VI you attached. If the example program works, make sure that you are setting up the pulse in the same way. Also, you still don't have a Stop Pulse function in the program...
