04-05-2014 06:30 PM
hi, I'm trying to do a draft color pattern recognition, but labview gives me this error, I hope you can help me, let the files, thank you very much
Error -1074395384 occurred at IMAQ Match Color Pattern
Possible reason(s):
IMAQ Vision: Invalid color template image.
04-05-2014 11:57 PM
image of diagram
04-06-2014 06:57 AM
I can't see your block diagram clearly due to the low resolution, but did you create a descriptor of your color template (using "IMAQ learn color pattern")?
K
04-06-2014 11:53 AM
thanks for reply
Yes i using "IMAQ learn color pattern", thanks again
04-06-2014 12:00 PM
Sorry im using, IMAQ Color Pattern Matching and IMAQ Setup Match Color Pattern
04-06-2014 12:13 PM
04-06-2014 03:50 PM
Hello
template was added to the route shown this in my documents with the name of pastillas1.png
I tested U64 and u32, u32 and u32, to try to correct the error but could not
regards & thanks
04-07-2014 02:36 AM
like I said, did you learn the color template information using IMAQ Learn Color Pattern prior to template matching? Or did you just create the template using some external image editor?
Check the Color Pattern Matching example under Labview examples.
K
04-08-2014 10:55 PM
im create the template using some external image editor, i dont know how make whit IMAQ Learn Color Pattern.
can you help me, please?
regards from mexico
04-09-2014 03:48 AM
the general idea is:
K
