Machine Vision
Showing results forĀ
Search instead forĀ
Did you mean:Ā
Error 1714: installation failure
I tried updating my version of NI-IMAQ from 2.5.5. When attempting an installation of NI-IMAQ 3.0 I get the following error message: Error 1714: "The older version of NI-IMAQ 3.0 cannot be removed. Contact your technical support group." How can I install NI-IMAQ 3.0?
(3,386 Views)
Did you uninstalled 2.5.5 before run the setup of 3.0? Is it possible that there is an old registry key of LabVIEW 6.0.2 at HKEY_Classes_Root>>Installer>>Products? It should help to delete these file. But export you current settings before.
Another and better way could be to use Msi Clean Utility (attached) to remove the MSI information regarding LabVIEW 6.0.2.
What means MSI Clean Utility: (http://digital.ni.com/public.nsf/3efedde4322fef19862567740067f3cc/8703592d07c91ad586256b44000248c6?OpenDocument)
(3,381 Views)
Solution see this  thread.
Waldemar
Using 7.1.1, 8.5.1, 8.6.1, 2009 on XP and RT
Don't forget to give Kudos to good answers and/or questions
(3,200 Views)
