Machine Vision
Error - 1074397153 occurred at IMAQ Grab Setup.vi
The sensor we are using is Goodrich SU640KTSX. I can run SUI image Analysis 3.1 software, Measurement & Automation software, and MATLAB code on an XP machine with no errors when grabbing images. We are tying to build a newer PC;
Dell T7500 with Intel xeon CPU x5650 @ 2.67GHz
Memory; 12GB
OS Win7  64-bit
Camlink card is NI PCIe-1430
Nvidia QUADRO 4000
The error we get is "Error -1074397153 occurred at IMAQ Grab Setup.vi / Cannot detect recognizable video source" when using the SUI image Analysis 3.1 software or MATLAB code. When we use the NI-IMAQ i/o 2.3.1- Measurement & Automation  I can snap, grab and record without any error.
Any help on this would be great
(4,607 Views)
Airabas
Unfortunately we do not test or support 3rd party software listed in your post. It is possible that OS or HW changes could have caused this issue.
I think your best option is to contact individual manufactures to get more details on this problem.
(4,586 Views)
Let us know which standard your camera is following (whether it is cameralink or ethernet).
Check this link for error info: http://digital.ni.com/public.nsf/allkb/3434173630CBC97686256F8000536593.
If at all it is cameralink camera make sure that you are following proper trigger sequence for your camera. As u are grabbing frames in MAX and not in other acquisition softwares it might be triggering issue or cables problem.
(4,543 Views)
