在 01-04-2006 02:40 PM
Hi PReitano:
The MAX communicator is GPIB and not VISA. Although it should still work it would be interesting to see if you get the same results with the VISA Interactive Control in MAX. Go to Tools->NI-VISA->VISA Interactive Control then double click your instrument. This will open the VISA Test Panel. From here try to write your command.
Let's start with that.
Emilie S.
