Machine Vision
Error 0x80070651 error code passed into imgShowError is unknown in IMAQdx
We are trying to capture images from our gigE IP camera (DFK Z12GP031) through an USB to gigabit ethernet adapter. The settings and configuration has been done accordingly. But when trying to configure the camera in NI-MAX, it throws the error in subject and disables the camera. Need to enable the camera each time.
System is Windows 7 64 bit OS.
Thanks in advance!
(4,209 Views)
I do not think you can use usb adaptor for this reason it will be make error any time
(4,156 Views)
