Machine Vision
annulla
Visualizzazione dei risultati per
Cerca invece
Intendevi dire:
Error 0x80040217 The error code passed into imgShowError is unknown
Risolto!
Vai alla soluzione
Megabite wrote:
The new camera outputs 15-bit monochrome data.  Can IMAQdx treat MEDIASUBTYPE_RGB555 or MEDIASUBTYPE_RGB565 as monochrome?
No, since those are all inherently color formats, IMAQdx presents a RGB32 pin to accept them. The only formats IMAQdx treats as monochrome are: MEDIASUBTYPE_RGB1, MEDIASUBTYPE_RGB4, and MEDIASUBTYPE_RGB8.
Eric
Messaggio 11 di 11
3.004Visualizzazioni
