03-25-2010 03:40 AM
Solved! Go to Solution.
03-25-2010 04:28 AM
03-25-2010 04:57 AM
I would like to think you for showing interest for the subject.
I will show more details, but first 1s is rapid when we look to ordinary scanner.Isn't?
The purpuse of the internship is to estalish a system to control documents to eliminate commun defects as values outside the tolerance or buffer lacking...
The first step is a real time documents scan. The is a wide variety of scan products among oter we find machine vision camera. Is it the best solution when we need rapidity(!!1s), cheap, PC interface(DLL needed),...
03-25-2010 05:01 AM
First unmark my previous post as "the solution". Since it is a very generic topic there is a nice possibility that you might get a different view points from others as well. Marking a thread a solution will get lesser hit comparitively....
I am not getting this. Can you try and put it in some different words?
03-25-2010 06:08 AM
I am so sorry I can't unmark it. Perhaps you can help me to do that.
documents are filled by workers and several faults may affect them such as the values written are outside the tolerance
or the lack of informing a stamp or signature
03-25-2010 06:16 AM
03-25-2010 07:12 AM
03-25-2010 07:25 AM
03-25-2010 07:34 AM
It is a monotoring task, but in the end of operation of image processing the document will be saved in data base if it is ok else a defect is signaled.
03-25-2010 07:49 AM
