キャンセル
次の結果を表示
次の代わりに検索
もしかして:
Differential video using IMAQ-A6822 breakout box with 1409?
I'm not able to find info anywhere telling me how to connect my differential video signal through the A6822 box.  When connecting directly to the 1409 with a custom cable, we are using +/- VIDEO1 which works fine.  The A6822 has Video 0 - 7 inputs, with the BNC shells all connected to all the other BNC shells of all other signal inputs, so I can't connect one side of the video signal to the BNC shell.  I found the A6822 installation guide, but that doc gives no practical info at all.  I found by a search the knowledgebase article about removing a jumper from the 1409 only when using the breakout box to eliminate a noise problem, so I'm trying that as well.  Can we look at differential video through an A6822?
- Brad
0 件の賞賛
メッセージ1/7
5,769件の閲覧回数
Hi Brad,
Thanks for posting! BNC connections are themselves differential connections.  So to answer your question, yes you can look at differential video with the A6822.  To do this, use a BNC cable and connect your camera to either Video 0, 1, 2, or 3 (since the 1409 has these 4 input channels).
Do you not have access to these channels?
I hope this clears things up.  Let me know if you have more questions or if there are some details I need to be made aware of and I'll be happy to help.
Tejinder Gill
Applications Engineer
Visit ni.com/gettingstarted for step-by-step help in setting up your system.
0 件の賞賛
メッセージ2/7
5,751件の閲覧回数
An ohmmeter shows that the outside shells of the video BNCs are connected to the outside shells of the sync inputs, etc.  They are definitely not isolated, so each video input can't be differential.  Who has a schematic diagram of that breakout box and the corresponding IMAQ-1409 cable?  Those are what we really need to see.  I couldn't find them online.  Is there any way you could post them?
Brad
0 件の賞賛
メッセージ3/7
5,743件の閲覧回数
Hi Brad,
I apologize, I believe you are correct.  Looks like the BNC's are in fact connected to common ground.  Unfortunately I do not have schematic diagrams for this breakout box.
What happens if you connect through the breakout box?  Does it result in unexpected results?  I haven't yet come across a situaton where the A6822 has caused unexpected results with the 1409.   If so, please let us know!
Tejinder Gill
0 件の賞賛
メッセージ4/7
5,724件の閲覧回数
When we connect only one side of our differential video (the + side) to an A6822 video input, the video looks smeared and noisy.  However, as somewhat of a temporary, partial, Band-aid fix I've been connecting the negative video to another video input which cleans up the video being captured quite a bit.  I'm not sure if it's the additional 75-ohm load that is doing it, but it helps a lot for now.  I'm just going to have to get our SCB-68 interface box and use it in place of the A6822 while still using the 68-pin IMAQ cable.  We'll see how well that works.
I'm suspecting that the A6822 is something that is not meant to be used with any differential signals at all.  So, there is no way to get schematics from whoever designed and/or built that breakout box?
- Brad
0 件の賞賛
メッセージ5/7
5,708件の閲覧回数
I couldn't find the IMAQ cable (used with the A6822) listed for sale on ni.com, so an email to a sales rep got a quote for it.  If anyone needs one, it's part #186823-01.
I connected a SCB-68 box to the A6822 with a cable, then used an ohm meter to check pinouts.
For the IMAQ cable pinout: corresponding pins on both ends are connected to each other (as you would expect).
The A6822 pinout is in the attached files.  The files correlate pin numbers, 1409 signal names and A4822 connectors.  The A4822 breakout box definitely cannot work with differential signals - with one odd exception.  Only the PCLK OUT connector has an isolated BNC shell (it's connected to the 1409 PCLKOUT(-) signal and not to other BNC shells).  However, the PCLK IN connector's BNC shell is tied to DGND and other BNC shells, so you can't loop a 1409-generated clock from the OUT to the IN directly.  I think the designers of the box had a few too many at the local pub as they drew it out on the back of a napkin.  It's too bad... it could have been a much better (more flexible) breakout box if it had been wired differently internally.
0 件の賞賛
メッセージ6/7
5,687件の閲覧回数
Wow... what a difference the SCB-68 box makes.  I have a beautiful, stable capture now using all differential signals through the IMAQ cable.  Amazing what a difference differential signals make along with the right hardware.
By the way... if anyone wants to know how I used a simple ($49) Avnet Spartan 3A FPGA card to generate an HSYNC signal for our very oddly-formatted video signal, I can go into that.  It allows the 1409 to capture our strangely-interlaced, 1020 by 240 video format.
- Brad
0 件の賞賛
メッセージ7/7
5,667件の閲覧回数
