Machine Vision
Creating install for IMAQ Application
Hi
I am writing a app using NI Vision Developement Module version 8.5, a NI PCIe-1427 Cameralink grabber in VB.Net2005.
I have a vision run-time license for my client.
I need to know how to create an installer and get IMAQ and Vision running on their PC.
Do I just use the Visual Studio Setup Wizard project?  Are there any special instructions I need to know?
Bestbier
(3,591 Views)
I only use LabVIEW so I can't garranty it works exactly the same but what I normally do is :
- build an installer with LabVIEW that includes the Vision run time and the LabVIEW runtime,
- launch the installer on the client's PC,
- when I first lauch the application, a window pops up saying that I can either activate the vision runtime or use the evaluation version for 30days,
- to activate, the vision runtime you need the client's serial number with which you get another number on a NI web page,
If you follow this, it works.. the thing is you need the client's PC AND an internet access.
Hope this helps
Epictetus
Antoine Chalons
(3,580 Views)
Hi
Thanks for that.
I will probibly first install the vision run-time engine manually, because I will have to make changes and then recompile and reinstall.
Regards
Bestbier
(3,576 Views)
