Machine Vision
Coutour Match - Scale range 1 direction axis
I have an application where I have to fit a contour with a template.
Depending on the angle of view, this part can be bigger but only in one direction. Running the option "scale" of the match contour function doesn't work because it try to scale in both x and y direction.
Do you have an idea of how I could implement that?
(for better understanding of my problem, imagine a fixed camera that is on top of a part that is on table, if you change the angle of that part on the table in one direction, the part will have the same width but will change in height.)
Thanks for you help.
Patrick
(2,179 Views)
Hi Patrick,
What software package are you using? Could you include sample images and a sample project of what you are trying to do?
Zofia
NI Technical Support Engineer
(2,134 Views)
