Hello George,
You will need the NI-IMAQ driver that comes bundled with the NI Vision Acquisition Software. NI-IMAQ will allow you to acquire from a JAI-M4+CL camera in LabVIEW. You will also need the camera file for the JAI-M4+CL camera.
Best Regards,
T. McCarty
The NI-IMAQ driver *WON'T* allows you to acquire images from the Coreco PC-CamLink acquisition board.
You can purchase a driver that does exactly what you want from a company called Alliance Vision. The driver is a set of VIs that calls into the Coreco driver and interface nicely with LabVIEW and the NI Vision library.
Here is the link to what you're looking for:
http://www.alliancevision.com/us/products/software_alv/coreco_pcvision/fr_pc_vision.htm
Hope this helps,
-Christophe
Hi all,
I think interfacing a framegrabber with LabVIEW can be much harder than Kaccie said.
You will need to have a good knowledge of C/C++, in order to develop a dll which takes care of many things, and especially of image pixels transfer. This means handling correctly the image border, different pixel depths, memory alignment, etc... (the image in memory may not be stored in the same way in the IFC driver and in LabVIEW and you will have to take care of that).
This is the job we have done at my company : Alliance Vision.
Our driver supports all Coreco framegrabbers, and it has been tested with many differents cameras (Analog, RGB ,camera Link,...). Our driver is well documented, and we also provide free technical support.
You can purchase it from our company (www.alliancevision.com), and from our United States partner which is Graftek Imaging (www.graftek.com)
Best Regards.
Jean-Chrisotphe BENOIT
Alliance Vision
George,
Not a problem. I have a PC-dig grabber running a dalsa camera. I can give you the c file that compiles into a dll (done in MS visual studio 6.0) and a VI that puts a while loop around this dll, grabbing an image each time. Do you have an email address? Mine is kaccie_li@hotmail.com.
By the way, I'm pretty confident that Alliance vision "drivers" work great. The only problem is that they are expensive and they wouldn't provide me with a demo to gurantee that it works. So it was hard to persuade my advisor to purchase it.
Kaccie
oops, didn't see George's email address there at first. I'll attach the files to you as soon as I can.
Kaccie
