Machine Vision
Complex Image - 3D View
I was trying to 3D-display some complex image data. The 3D View function accepts CSG images, allows you to select a plane (standard option= 2 /  magnitude), and displays that. (http://zone.ni.com/reference/en-XX/help/370281M-01/imaqvision/imaq_3dview/)
It doesnt seem to work. I get a "Error -1074396077 occurred at IMAQ 3DView", which means inconsistent datatype.
I implemented a minimal example showing this behaviour:
The workaround is trivial.. extract the desired plane, use IVA Dynamic Adjustment to get to U8, done.
However, I'm a bit worried that I have a corrupted system, because this is not the first time I stumble upon inconsistent behaviour with the CSG datatype. Can you guys confirm that you have  same issue as I do? I don't really want to reinstall my machine, because I've customized a lot.
Thanks a lot,
B
(4,577 Views)
Accepted by b.ploetzeneder
Hi B,
            I believe the reason you were enctountering the error is because you missed an input for the IMAQ 3DView.vi . Attached you will find the your example, but modified. See if it solves the isse 😉 .
Denis
(4,530 Views)
Hi Denis,
yep, works.  mhmm.. I get the point that the VI modifies the src reference and turns it into an U8.
Still.. I would have expected it to work on the first run, or at least there should be a note in the documentation that a dst reference is required for CSG. There's a lot of sloppy programming with that datatype, mainly because nobody seems to use it as much as I currently need to.
B
(4,527 Views)
