Machine Vision
Capturing image sequences - issues with nested for loops
Hi all,
I've written a vi. to capture a specific number of images ('Image No') and save these images, outputted to a folder of my choice.  Each image is identified sequentially.  However, I wish to do a number of iterations ('Run') of this capture sequence, such that the filename of each image would be 'Filename (Run)_(Image No).png', e.g. run 5, image 10 would be 'Filename 5_10.png'.  I have tried a nested for loop for this but I receive an error 'Asynchronous I/O operation in progress' (I've attached a printscreen).
Can anyone assist me in solving this problem?  Please find attached my vi.
Kindest regards and thanks,
Miika
(3,414 Views)
You cannot create a folder if this one is already existing.
Just check that the folder exists before creating it.
Regards
(3,388 Views)
Accepted by topic author CP Miika
Hi toto26,
Thank you for your reply.  I solved the problem by using a flat sequence structure - folder in first frame and all subsequent processing in the second.
Miika
(3,379 Views)
