Machine Vision
Capturing image sequences - issues with nested for loops
Hi all,
I've written a vi. to capture a specific number of images ('Image No') and save these images, outputted to a folder of my choice.  Each image is identified sequentially.  However, I wish to do a number of iterations ('Run') of this capture sequence, such that the filename of each image would be 'Filename (Run)_(Image No).png', e.g. run 5, image 10 would be 'Filename 5_10.png'.  I have tried a nested for loop for this but I receive an error 'Asynchronous I/O operation in progress' (I've attached a printscreen).
Can anyone assist me in solving this problem?  Please find attached my vi.
Kindest regards and thanks,
Miika
(3,239 Views)
You cannot create a folder if this one is already existing.
Just check that the folder exists before creating it.
Regards
(3,213 Views)
Accepted by CP Miika
Hi toto26,
Thank you for your reply.  I solved the problem by using a flat sequence structure - folder in first frame and all subsequent processing in the second.
Miika
(3,204 Views)
