Machine Vision
Cannot Open u16 RAW (binary) Image in Vision
Have another U16 Image question.  Trying to open a U16 raw image.  Opens fine in ImageJ with the following options:
I duplicated these settings using this simple code
But I get the error: "Error -1074396074 occurred at IMAQ ReadFile
Possible reason(s):
IMAQ Vision:  Incompatible image size."
Image should look like:
I am posting the file "Martha 1849-02-001-6-view0000_raw_grey_32bit.raw" at ftp://ftp.ni.com/incoming if you would like to try.
Don
(5,247 Views)
Accepted by DonRoth
The help says "If you are reading a nonstandard file format, you must set the size of Image to match the contents of the file before using IMAQ ReadFile".
Use IMAQ SetImageSize to set the size to 3888 x 3072 and it works.
-Christophe
(5,241 Views)
Thanks.  This makes perfect sense. I missed this when reading the help on the function.  And it works.
What I would suggest to the NI Vision team is that they add X and Y size (resolution) parameters to the 'File Options' cluster IMAQ ReadFile VI.  Then a complete specification would be available in just this one function.
Thanks again.
Sincerely,
Don
(5,231 Views)
One question  related to this - anyway to open raw binary file in Vision Assistant?  Doesn't seem to be.  This should certainly be added as an option and have a dialog spawned with File Options control.
Don
(5,136 Views)
Unfortunately, there is no way currently to open a RAW file in Vision Assistant. I filed feature CAR 326887 to address it in a future version.
I can't give you a timeline, as features are prioritized for each version, but we have a trace of that request now.
-Christophe
(5,132 Views)
Thanks. This one should be simple to implement for a future version since you already have the underlying code to do it in Vision.  I would think a lot of folks would be interested in this.
Don
(5,128 Views)
