11-30-2010 07:03 AM
I am using Labview 2009 in my lenovo X61 laptop with Windows 7 installed (64-bit).
I have played a little with Vision Assistant 2009 and results with my images are pretty good. Now I would like to get same functions to work in LabView. I try to do "tools" - "create labview VI..." in vision assistant. All goes well..., until the point I should see the code. Vision Assistant opens Labview "Getting Started" window, but then nothing happens. I don't see VI in my specified folder and all stops there. ![]()
If anyone of you have an idea how to solve this problem I would be very happy.
Tommi
Solved! Go to Solution.
11-30-2010 09:13 AM
There is a known issue with code generation in Vision Assistant 2009. Check out this KB:
http://digital.ni.com/public.nsf/allkb/DFB0B9C7F817D66386257626005A5825
Also, in the LabVIEW options (Tools>>Options) make sure that you the Active X protocol is enabled and grant access to a VI called "IVA Create LabVIEW VI.vi" in the Exported VIs list.
-Christophe
11-30-2010 11:11 AM
Thanks Christophe for quick reply! I decided to fix the problem by installing Labview 2010, and Vision Assistant works now just as it should.
So now I can generate LabView code out of Vision Assistant skecth, very nice!
