02-18-2009 02:30 PM
02-19-2009 12:15 PM
Hi Kristen
Thanks for the update.
The problem with having the camera file generate the pulse is that i need to be able to vary the length of the pulse. It need to be 33 or 150ms high and 5ms low.
I will look into generating the pulse with the camera file.
Hopefully the new driver is availible soon.
Bestbier
02-20-2009 10:38 AM
Hi bestbier!
You should still be able to use the camera file to generate pulses of either 33 or 150ms high with a 5ms low. You would just create two different modes on the same control line (or different if you need that) and then specify programmatically which mode you want to use at that time.
Kristen H.
02-20-2009 12:21 PM
Hi Kristen
Thanks for the info.
I should be able to do it like that until the driver bug is fixed. I will check how to do it.
Thanks for all the help.
Bestbier
03-16-2009 02:40 PM
Hi Kristen
I finally got around to trying to generate the pulse using the Camera File Generator. I just have one question: You can select the control line(0-7) in the pulse generation tab. From what I understand Control line 0-3 corrospond to CC line 1-4. Control line 4-7 are internal control lines? My camera does not use the cameralink CC lines so If I generate a pulse on Control line 4, how do I route that signal to be on TTL_Trig(0)?
Bestbier03-17-2009 04:09 PM
Hi bestbier!
I think this KnowledgeBase article will explain it well for you. Let me know if you have any other questions!
Kristen H.
03-18-2009 12:02 AM
Hi Kristen
I have found that article while searching around and it deals with the routing to the Camera control lines. I need to route a pulse setup in Camera file generator to a TTL Trigger line. My camera does not support the CC lines so I need to run the trigger via an extra cable from a TTL Line.
Bestbier
03-18-2009 06:40 PM
Hi Bestbier!
My apologies- I read that wrong. Are you able to configure route in MAX in the Signal Level tab? If not, I will have to ask R&D, since I was not able to find documentation with explicit instructions.
Kristen H.
03-19-2009 03:12 PM
Hi Kristen
I don't currently have a 1427 in my developement computer so I can get back to Signals tab in MAX.
I have looked around the signals tab, but as far as I remember you can only setup your incoming signals - either TTL0 or ISO0.
Bestbier
03-20-2009 02:29 PM - edited 03-20-2009 02:30 PM
Hi bestbier
I looked under the signals tab for my 1427. Here is what I saw:
Looks like it configures both input and output tirggering. If possible, can you test it out?
Kristen H.
