Machine Vision
Cameralink triggering
Hi bestbeir
I have two bits of information for you.
First, the button being grayed out is actually a bug with the driver.  R&D is currently working to fix it and will, hopefully, have a patch for it soon.
Second, as far as triggering your camera link camera, I learned that is best way to control this through the camera file.  You can make modifications to your camera file using the camera file generator.  Within the camera file generator you can specify the amount of time you want your pulse to be high and how long it is low before it goes high. Go to the Camera Control tab to add your triggering.  Add an attribute for triggering.  Then under the Actions section there is a Pulse Generation tab.  You can add your pulse generation specifications by clicking Add and configuring the pulse to what your application needs.  Therefore, you will use the trigger configure function from the API.  The frame grabber will then wait for the signal before sending the pulse to the camera, as specified by the camera file.
I hope this helps!
Kristen H.
Message 31 of 48
(2,613 Views)
Hi Kristen
Thanks for the update.
The problem with having the camera file generate the pulse is that i need to be able to vary the length of the pulse. It need to be 33 or 150ms high and 5ms low.
I will look into generating the pulse with the camera file.
Hopefully the new driver is availible soon.
Bestbier
Message 32 of 48
(2,598 Views)
Hi bestbier!
You should still be able to use the camera file to generate pulses of either 33 or 150ms high with a 5ms low.  You would just create two different modes on the same control line (or different if you need that) and then specify programmatically which mode you want to use at that time.
Kristen H.
Message 33 of 48
(2,591 Views)
Hi Kristen
Thanks for the info.
I should be able to do it like that until the driver bug is fixed. I will check how to do it.
Thanks for all the help.
Bestbier
Message 34 of 48
(2,586 Views)
Hi Kristen
I finally got around to trying to generate the pulse using the Camera File Generator. I just have one question: You can select the control line(0-7) in the pulse generation tab. From what I understand Control line 0-3 corrospond to CC line 1-4. Control line 4-7 are internal control lines? My camera does not use the cameralink CC lines so If I generate a pulse on Control line 4, how do I route that signal to be on TTL_Trig(0)?
Bestbier
Message 35 of 48
(2,505 Views)
Hi bestbier!
I think this KnowledgeBase article will explain it well for you.  Let me know if you have any other questions!
Kristen H.
Message 36 of 48
(2,494 Views)
Hi Kristen
I have found that article while searching around and it deals with the routing to the Camera control lines. I need to route a pulse setup in Camera file generator to a TTL Trigger line. My camera does not support the CC lines so I need to run the trigger via an extra cable from a TTL Line.
Bestbier
Message 37 of 48
(2,488 Views)
Hi Bestbier!
My apologies- I read that wrong.  Are you able to configure route in MAX in the Signal Level tab?  If not, I will have to ask R&D, since I was not able to find documentation with explicit instructions.
Kristen H.
Message 38 of 48
(2,470 Views)
Hi Kristen
I don't currently have a 1427 in my developement computer so I can get back to Signals tab in MAX.
I have looked around the signals tab, but as far as I remember you can only setup your incoming signals - either TTL0 or ISO0.
Bestbier
Message 39 of 48
(2,458 Views)
Hi bestbier
I looked under the signals tab for my 1427.  Here is what I saw:
Looks like it configures both input and output tirggering.  If possible, can you test it out?
Kristen H.
Message Edited by Kristen H. on 03-20-2009 02:30 PM
Message 40 of 48
(2,440 Views)
