‎05-10-2009 03:47 AM - edited ‎05-10-2009 03:48 AM
Hi guys::
I have a problem about camera id, there are two 1394 cameras, now in my "Measurement & Automation" , they are as follows:
cam0: Point Gray Research Flea2 FL2-20S4C
cam1:TELI CSFV90BC3 V1.10
If i do really wana to set "TELI CSFV90BC3 V1.10 " as cam0, and set "Point Gray Research Flea2 FL2-20S4C"
as cam1, what can i do? i mean is that possible to set sepcified cam id as i want?
thanks
‎05-10-2009 06:59 AM
It would be great if you could tell us why you want to do this. Have a look at the following articles:
Changing Interface Names of FireWire Cameras in MAX
Programmatically Finding Attached IEEE-1394 Cameras
‎05-10-2009 09:34 AM
‎05-10-2009 11:25 AM
‎05-12-2009 09:41 PM
I know what you mean , and also prefer the second link method, but base on some certain reason, i need the first link,
any way ,thanks a lot!
