Machine Vision
CVS-1458RT External HDD via Ethernet Sharing
Is there a way to acquire saved images from an external HDD on the CVS via ethernet sharing?   The use would be e.g., saving imagery to an external HDD (on the CVS) and then trying to access those images via. another PC that's connected to the CVS's network port.
(2,554 Views)
Accepted by gscarbo
There are a few ways you could use in order to transfer files from your CVS to your computer. This document goes through these methods: http://digital.ni.com/public.nsf/allkb/FE7B38ACAF00E85586257EAF0070E354
I hope this helps!
T. Le
Vision Product Support Engineer
(2,509 Views)
Thank you!  That is what I needed!
(2,492 Views)
