Machine Vision
C1083: Cannot open include file: 'nivision.h'
I am using Microsoft Visual Studion 2008, and want to try NI Vision example "Threshold And Label", located in
"c:\program files\national instruments\vision\examples\msvc\threshold and label".
I open "Threshold And Label.dsw", try to Build. But
c:\program files\national instruments\vision\examples\msvc\threshold and label\stdafx.h(26) : fatal error C1083: Cannot open include file: 'nivision.h': No such file or directory
is fallen.
(4,059 Views)
Hi kirill,
Hopefully this KnowledgeBase will be of some help.
(4,036 Views)
Except it appears to be out of date...
Newer versions of NI drivers all place their C header/lib files under the following location:
C:\Program Files\National Instruments\Shared\ExternalCompilerSupport\C      (add \include or \Lib32 or \Lib64)
Follow the instructions in the KB but use this modified path instead.
Eric
(4,033 Views)
Thank you. I've added include and lib paths, and now it works!
(4,020 Views)
