Machine Vision
Bayer U16 2D array
Hello
I am using a custom camera driver which gives me image data as Bayer formed data as an U16 2D array. I am wondering if I can use the "IMAQ Bayer To RGB" function with this.
I would be most thankful for hints.
D. Ackermann
(5,374 Views)
Accepted by DAckermann
Yes, this VI lets you do just that:
http://zone.ni.com/reference/en-XX/help/370281U-01/imaqvision/imaq_bayer_to_rgb/
You would use ArrayToImage on the source image first, of course.
Eric
(5,358 Views)
I am getting some result with this. But the colors arent correct.
I dont really know how to create the src image with the 12bit sensor data.
I can't upload the image because of size. So only a screenshot of the result and my vi.
Maybe someone can help.
Bayer
(5,351 Views)
I can't see your VI at the moment, but did you set the bit depth to 12-bit on the source image?
(5,343 Views)
It seems everything is working fine now.
Thanks!
(5,330 Views)
