‎08-18-2017 04:34 AM
Automatic threshold using inter-class variance is described in the NI vision help as shown in figure below. My question is what is the difference between the last two equations; they are exactly the same. what do they indicate ?
‎08-21-2017 12:53 PM
Hi Ahmed_Kotb,
Let me preface this by saying I don't have quite the in-depth knowledge need to for a deeper understanding of the algorithm in question. However, I believe I can provide the information you need.
Inter Variance thresholding chooses a threshold value that maximizes the first expression in the image you include. The three equations below that simply provide definitions of the values used in that same equation, and the two in question just happen to be equivalent. If I'm understanding correctly, the algorithm starts with a Histogram. N is the number of bins in that histogram, and I believe p(i) is the value of that index in the histogram.
Again, I could be wrong as I'm working from the same information as you are in the help documentation. I believe the above is correct, though.
‎08-22-2017 01:02 AM
‎08-22-2017 11:11 AM
Hi Ahmed,
You are right that there is a type error in the equations.
On the last equation the summation index is going from i=0 to i=k. Not i=0 to i=N-1.
I was just looking at my favorite book "Digital Image Processing using Matlab" by Gonzalez, Woods and Eddings.
This book has good explanation of Otsu's method for global thresholding (it is interclass variance) and has the source code in matlab.
Chapter 11.3.3 in the book is "Optimum Global Thresholding Using Otsu's method".
‎08-23-2017 09:47 AM
Hi all,
With the disclaimer that I am not as familiar with the low level algorithms, I did speak briefly with a colleague and we think there may infact be a typo in the documentation along the lines of what AmitShachaf describes. We're not 100% sure, but I went ahead and filed a Corrective Action Request to have R&D take a closer look at the documentation in question.
