From Saturday, Nov 23rd 7:00 PM CST - Sunday, Nov 24th 7:45 AM CST, ni.com will undergo system upgrades that may result in temporary service interruption.
Machine Vision
Anyone with experience of using the C4 3D imaging camera from Automation Technology?
This camera uses User Sets to store specific configurations. In MAX I set it up so User Set 2 is Image mode and User Set 3 is COG mode. Switching between the two sets involves selecting a user set and then pressing "Execute".
Now I'm trying to make this switch programmatically. I'm using Property Nodes to write the attributes I need, but I can't see how to Execute. I write the attribute as shown below, but there's no option for a Command, which is what I think is needed. (So far I've left it at "Description" which clearly isn't right.) Suggestions?
(2,208 Views)
Accepted by topic author another_novice
The equivalent of "Execute" for a command in LabVIEW is writing a boolean value of True (see attached).
Hope this helps,
Katie
(2,204 Views)
Thank you Katie.
(2,190 Views)
