Hi jch303,
Thanks for using our discussion forums! There are a few things you might want to try here.
First of all, if you really want to stick with the laptop, the Data Acquisition should be pretty easy to put together- we have quite a few different models of PCMCIA DAQ devices. I'm not sure how many channels you need or what resolution or sampling speed you need though. Here is a link to our DAQ devices, and if you provide some specs, I'd be glad to recommend one:
http://sine.ni.com/apps/we/nioc.vp?cid=13873〈=US
With regards to the analog image acquisition, this is the tricky part. Unfortunately, we don't offer any analog image acquisition devices for laptops. If you are looking to acquire images on a laptop, you might want to consider using an IEEE 1394 (firewire) camera instead of analog.
Another option that would be quite easy to integrate would be to use a PXI chassis instead of a laptop. In this case, you could simply buy a small 4 slot chassis with a controller, analog IMAQ module and M-Series DAQ module. Synchronization would be very easy and the PXI chassis would be smaller than a full sized PC.
Let us know if there's anything else we can help with.
Regards
Dan
