‎06-22-2009 09:11 AM
I have two AVT StringGray Cameras F033B and F033C. And I have Windows XP SP3. I read through the discussion and get to know that the IEEE decreased speed issue is fixed in SP3. But in MAX, when I use generic 1394 to control the cameras, I can only set the speed to 100M (this is the only option). I use 1394B connection which is suppose to give me 800M. I wonder if there is a solution?
Also, I tried the driver provided by AVT. It can work properly in S800. But it seems that this driver is not supported in MAX?
Thank you.
‎06-22-2009 09:19 AM
In fact Microsoft did not fix their S800 problem in XP SP2 nor SP3, nor in Vista. Thankfully they apparently have fixed it in Windows 7 release candidate.
In the meantime, please see several effective options described in the AVT technical support knowledge base article at http://goavt.mykb.com/Article_249D6.aspx
Scott Smith
Allied Vision Technologies
‎06-23-2009
02:43 PM
- last edited on
‎11-21-2025
10:17 AM
by
Content Cleaner
Hi evert,
Have you seen this?: NI Knowledgebase: NI-IMAQ for 1394 or NI-IMAQdx: Slower Frame Rate After Upgrading to Window XP SP2 or later
Here's another potentially helpful KnowledgeBase.
I hope these help!
Kristen H.
‎06-23-2009 02:55 PM
