MATRIXx
normal random generator
Can I customize "normal random generator" to have a input for seed unless a parameter data? In both, "block" and "block script" solution a only can use seed like a parameter.
Thank´s in advance.
(12,808 Views)
Could you please explain better your doubt? Please give me more details.
Thanks.
Best Regards
Luciano Borges
Test Development Engineer
(12,802 Views)
OK.
OBJECTIVE: Create several dll for models using a Normal Random Generator Block
ACTION: Change the "PARAMETER SEED" to a "INPUT SEED". This way, I will config the dll without need a new compilation with diferent seed parameter adjusted for each dll.
Thank´s.
(12,800 Views)
I sent to you a Private Message.
Please take a look at it.
Thanks.
Best Regards
Luciano Borges
(12,789 Views)
