04-16-2010 04:57 PM
I am developing a new monitoring project, and once again I need your help. I use Labview 8.2 on Ubuntu 8.04 and I need to create a web services in order to exchange data between Labview and a Apache server. As you know web services (package by NI) is not available for Linux. I would like to use methods of http protocol like get, post, delete, etc. Is it possible to create using data socket (or other way) the method post for example?Basically my program is always checking if one user has touch one file, if the created date of the file has changed my program will send the measures through the post method on a XML file. I suppose that it is easy to check the creation date of the file using labview code but, how could I "to simulate" the post in order to send the XML file?Thanks in advance04-19-2010 10:41 AM
You don't want to use datasocket, but you can use the TCP primitives. The protocol for HTTP is documented in RFC 2068 (http://tools.ietf.org/html/rfc2068). That said, if you do some searching you can probably find some existing G implementations of the HTTP protocol.
04-20-2010
06:18 PM
- last edited on
10-12-2026
03:05 PM
by
Content Cleaner
Hi AdamKemp,
thanks for your answer, I have been looking for something in OpenG but without success. If I must build my own http protocol with your suggested link... better I look for a other way using a external code. Nevertheless I have found a way to create the method post and get using soap, but I don't like the solution (.net).
04-21-2010 12:24 AM
OpenG has an attempt at a HTTP VI library but not exactly in a state that would warrant release of a package. It has also not been ported to the new SVN repository but should still be available in the old CVS repo. You can also access it through the viewcvs interface http://opengtoolkit.cvs.sourceforge.net/viewvc/opengtoolkit/http/.
04-21-2010 10:13 AM
SOAP is a lot more complicated then you probably need. I suggest checking out Rolf's link at least as a starting point.
It basically just comes down to figuring out what string you need to send (the format based on the protocol) and then you just create that string and send it over TCP/IP to port 80. The hard part is just figuring out what that string needs to be. There are some plugins to firefox you can use to spy on HTTP messages so you could just simulate it in firefox and see what string it sends, then modify that. Or you can start with an example like Rolf's and modify it as needed.
