Linux Users
Problem in installing Drive(DMM2.5)
hi,guys!
i have a problem in installing DMM2.5(DMM hardware drive) on SUSE10.3
run"./INSTALL"
because in the README.txt ,there are words below:
    No linux-2.6.22.5-31-default,so i change the directory to the /usr/src/linux-2.6.22.5.31
    show the same error.
    I try another way
    I have no ideal,Do someone know how to resovle the problem?Thanks!
(4,608 Views)
Looking at the readme for NI-DMM 2.5 [1], you're using a newer openSUSE distribution than what the installer is expecting to encounter. In this case, I would start over (and undo all of the changes you made), and then install the matching version of NI-KAL [2] for openSUSE 10.3 first, and then install NI-DMM 2.5.
Joe
[1] NI-DMM 2.5 readme
http://ftp.ni.com/support/softlib/digital_multimeters/DMM%202.5%20%28Linux%29/readme.txt
[2] NI-KAL Driver Search
http://search.ni.com/nisearch/app/main/p/bot/no/ap/tech/lang/en/pg/1/ps/10/sn/catnav:du,ssnav:sup/q/...
Joe Friedchicken
NI Configuration Based Software
Get with your fellow OS users
[ Linux ] [ macOS ]
Principal Software Engineer :: Configuration Based Software
Senior Software Engineer :: Multifunction Instruments Applications Group (until May 2018)
Software Engineer :: Measurements RLP Group (until Mar 2014)
Applications Engineer :: High Speed Product Group (until Sep 2008)
(3,629 Views)
Hi,JoeFrindchichen
I haved tried your ideal,i fail unfortnately.The same error.Maybe i have to change openSUSE distribution to openSUSE 10.0,thank you very much for your answer.
(3,629 Views)
Which version of NI-KAL did you try, and what commands did you type? Please run and attach the output from niSystemReport.
Joe Friedchicken
[ Linux ] [ macOS ]
(3,629 Views)
