Linux Users
New NI-RIO 3.5 FPGS Interface C API
Will the newly released NI-RIO 3.5 FPGA Interface C API for Linux work when you have DAQMx installed?
Reading the Readme file for the new NI-RIO 3.5 FPGA Interface C API for Linux, it states:
“To ensure the successful operation of National Instruments RIO products, you must use a kernel configuration that
recognizes only up to 4 GB of physical memory.”
Doesn’t the DAQMx drivers require a stack > 4 GB?
(7,836 Views)
The NI-RIO 3.5 will not work on 32 bit kernels with PAE (Physical Address Extensions) and >4GB of RAM, this isn't a limitation of NI-RIO 3.5 but of NI-KAL, this has always been the requirement. It should work fine with DAQmx installed as well.
(4,456 Views)
But from my knowledge, the DAQMx won't work if the stack is 4GB.  It needs a stack > 4GB. We have RedHat Enterprise 5.4 running with a stack > 4 GB and our DAQmx and NI-KAL is OK (or at least as far as we can tell). Does DAQMx use NI-KAL?
(4,456 Views)
Technically, NI-PAL (which DAQmx depends on) on 32-bit won't work when the addressable amount of memory is > 4GB, due to the data type we use internally for physical address, so we're limited to 32-bit. If you have more than 4GB memory, something will fail to load.
(4,456 Views)
I'm a little confused where this >4GB is coming from for DAQmx, it does use NI-KAL as do all NI drivers under Linux to communicate at that layer, the readme.txt shows the minimum system requirements well under the 4GB limit: http://ftp.ni.com/support/softlib/multifunction_daq/nidaqmx/8.0.1%20Linux%20Only/readme.txt
(4,456 Views)
I believe the confusion is based on system RAM versus kernel stack. As Irwan said, NI-PAL requires that fewer than 4 GB of system RAM be installed/recognized. DAQmx, on the other hand, requires an 8kB kernel stack for its internal data structures.
Joe
Joe Friedchicken
NI Configuration Based Software
Get with your fellow OS users
[ Linux ] [ macOS ]
Principal Software Engineer :: Configuration Based Software
Senior Software Engineer :: Multifunction Instruments Applications Group (until May 2018)
Software Engineer :: Measurements RLP Group (until Mar 2014)
Applications Engineer :: High Speed Product Group (until Sep 2008)
(4,456 Views)
My apologies.  Joe is correct.  I confused stack size and RAM size.  I did not read the Readme file correctly.
Thanks Joe!
(4,456 Views)
