Linux Users
fedora 64 bit problem with Call Library Function Node
Hi
I have LabView 2009 sp1 32bit that is installed on  64bit machine that runs Fedora 2.6.. I'm trying to call function from shared library that was created for 64bit. When I specify in the Call Library Function Node's VI window the path to shared library  it populates function name tab with all the functions that are in that library but when I click OK  an error 7 message pops up  "File not found. The file might have been moved or deleted, or the file path might be incorrectly formatted for the operating system. For example, use \ as path separators on Windows, : on Mac OS, and / on Linux.Verify that the path is correct using the command prompt or file explorer."
Did anyone had this problem and was able to solve it?
Please Help.
Grostmy
(4,009 Views)
You can't do that. A 32 bit application can only load and link to a 32 bit shared library and the same applies for 64 bit.
Rolf Kalbermatter  My Blog
(3,527 Views)
As rolf pointed out, you can only call 32-bit shared libraries from 32-bit LabVIEW (which is the only option on Linux right now). However, the behavior you described isn't very user friendly, so I filed a CAR (#243049) to give a better error message.
See if you can install a 32-bit version of that library and call that one instead.
(3,527 Views)
