Linux Users
NI Linux Device Drivers – dkms build failure on kernel 6.14.0-generic (nipalk DKMS Build Error)
Hello everyone,
I'm trying to install the NI Linux Device Drivers as part of NI-DAQmx 2025 Q2 on my clean vanilla system. I’ve also tried 2025 Q3 and 2024 Q2, but encountered the same issue during installation with:
sudo apt install ./ni-ubuntu2404-drivers-2025Q3.deb
System information:
  • Ubuntu 24.04.2 LTS (Noble Numbat)
  • 6.14.0-24-generic
The installation fails due to a DKMS build error in the nipalk kernel module, which causes cascading dependency problems with other packages.
The crash file reports: nipalk kernel module failed to build
And the corresponding make.log reports: make[3]: *** No rule to make target 'nipalk-bin.o', needed by 'nipalk.o'.
This seems to be a build system or packaging issue, but i'm a complete newbie here and might be missing something
Questions:
  • Is this a known issue with this kernel version or with Ubuntu 24.04 in general when using NI drivers? Or could this be a device-specific problem (seems unlikely, as this is a fresh installed system)?
  • Is there a recommended kernel version for NI Linux driver compatibility?
  • What would be the recommended solution to install these drivers?
Thank you in advance! If any additional information is needed, i’ll be happy to provide it
(883 Views)
Accepted by okkhor
Try the 2024 Q3 driver stack.  I have it successfully running on a fully updated Ubuntu 24.04.2 system.
NI Linux Device Drivers Download - NI
Edit: Sorry, I meant *2025* Q3 driver stack.  I see that you say you've already tried it.  Maybe the 2025 Q2 drivers weren't successfully removed from your system?
(862 Views)
Looking through your logs the earliest error is:
Error! Bad return status for module build on kernel: 6.14.0-24-generic (x86_64)
Consult /var/lib/dkms/nipalk/25.3.0f141/build/make.log for more information.
dpkg: error processing package ni-pal-dkms
Can you post the dkms log?
Formally only kernel 6.8 is supported. Consider rolling back to that?
(459 Views)
