Linux Users
Error -200157 in NI daqmx 8.0.2 for linux
Hi Everyone,
I'm using NI6133 on Redhat Eenterpirse 6.0(kernel version  2.6.32-71.el6i686) with NI daqmx 8.0.2 for linux driver. C APIs are used in my own application.
This error occured in my own application, and even in the examples.
Error -200157 occurred at an unidentified location
Possible reason(s):
Device could not complete the calibration operation.
Calibration could fail for the following reasons:
1. The actual reference signal applied for calibration was different from the value you specified. Ensure that the reference signal applied is the same as the values that were input.
2. The reference signal was not stable over the period of time that the hardware was being calibrated. Ensure that the reference signal specified is free of noise and does not drift over the duration of the calibration.
3. The device is not functioning properly.
I tried to search the error code on niweb and found little information. Appriciate if anyone could provide some help. Thanks in advance.
Message 1 of 1
(3,353 Views)
