08-08-2008 07:25 AM - edited 08-08-2008 07:28 AM
void test (void)Maybe there is a simple solution i cannot come up with: again, the memory leak persists even after leaving that subroutine. It only disappears after leaving the main programme..
int iLoop, iStatus;
char cDir[300];
char cLanguage[255];
char cErrorString[255];
int inum_elements,inum_sub_elements;
int iMaxIndex;
int iElementIndex;
int iSubElements;
int iElementLength, iValueLength;
int iLength;
int iSelIndex;
int iError;
int iIndex=0;
char str[255];
char str1[255];
char str2[9999];
char str3[255];
CVIXMLDocument document2;
CVIXMLElement xml_curr_lang,xml_element,xml_element_dummy,xml_element_dummy2;
CVIXMLAttribute xml_attr;
ListType list=0,sublist=0;
for(iLoop=0; iLoop<100; iLoop++)
// set pointer to requ. file
sprintf(Para.cParaID,"A 1"),
ui64ID=900360001;
GetProjectDir(cDir);
sprintf(proj_dir,"%s%s%I64d%s",cDir,"\\Data\\",ui64ID,".xml");
iStatus=CVIXMLLoadDocument(proj_dir,&document2);
sprintf(cLanguage,"de"); //sel language
xml_curr_lang=xml_element=xml_element_dummy=0;
xml_attr=0;
if(iStatus!=0)
CVIXMLGetErrorString (iStatus, cErrorString, 255);
if(iStatus==0)
ErrorHandler(CVIXMLGetRootElement(document2,&xml_element),"XML Error");
ErrorHandler(CVIXMLGetNumChildElements(xml_element,&inum_elements),"XML Error"); // => Root Verzeichnis adressieren
iStatus=CVIXMLFindElements(xml_element,"sprache",&list); // Sprachebene adressieren
inum_elements= ListNumItems (list);
// ------------------------------------------ nach Sprache suchen
iStatus=0;
iMaxIndex=0;
for(iElementIndex=0; iElementIndex<inum_elements; iElementIndex++) // Suchen, bis die gewünschte Sprache gefunden wird
ListGetItem(list,&xml_element_dummy,iElementIndex+1);
CVIXMLGetElementTagLength(xml_element_dummy, &iElementLength);
if(iElementLength>=255)
exit(0); // error handler
CVIXMLGetElementTag(xml_element_dummy,str2);
ErrorHandler(CVIXMLGetAttributeByName(xml_element_dummy,"id",&xml_attr),"Tag >ID< unter >sprache< nicht gefunden"); // => Root Verzeichnis adressieren
ErrorHandler(CVIXMLGetAttributeValue(xml_attr,str1),"ID liefert keinen Wert zurück");
if(CompareStrings(cLanguage,0,str1,0,0)==0)
iStatus=1;
break;
CVIXMLDiscardAttribute(xml_attr);
if(iStatus==0)
xml_curr_lang=xml_element_dummy;
CVIXMLDiscardElement(xml_curr_lang);
CVIXMLDiscardElement(xml_element);
CVIXMLDiscardElement(xml_element_dummy);
ListDispose(list);
ListDispose(sublist);
CVIXMLDiscardDocument(document2);
08-08-2008 11:18 AM
08-08-2008 01:25 PM
08-08-2008 03:35 PM
08-11-2008 01:22 AM - edited 08-11-2008 01:23 AM
08-11-2008 03:26 PM
08-13-2008 06:56 AM
l First of all thanks for the immediate reply. I´m still fighting on that problem... A few things i stumbled uppon the last two days:
*** CVIXMLCopyElement: there is sth wrong with the help text: the number of parameters do not match the parameters explained in the text and (what is worse) in no way matches what the compiler expected (even one more argument).
*** Beta CVI: as you recommended above, i applied for the beta software, but the standard form says, that this is updated on a yearly base (which could mean, that it may take 364 day to wait (worst case) until a reply arrives - which is not a good option right now)
*** Problem with that code line:
iStatus=CVIXMLFindElements(xml_element,"sprache",&list1);
I totally missed to allocate that list, but couldn´t find a example to explain to me, how i reserve a list of xml elements.
*** now i get problems with "dynamic momory corrput" at changing positions - looks like it changes according to the memory leak i just fixed.
*** Is there a way to find out, which elements are not cleanly removed (i found some hints which only work in lower version of CVI)...
Thanks for your advice...
Dominik
08-13-2008 07:58 AM
I did some more tries: i took my "real" program and commented out almost everything. The subroutine i included is run 100-200 times and the memory is allocated massively (about 100 MB). It runs the file i sent to your ftp server some days ago.
I´m really stuck in searching for the problem. I know those XML Elements at the end should be freed, but they tend to cause me errors when uncommented.
08-13-2008 02:30 PM - edited 08-13-2008 02:33 PM
Hi Dominik,
I'm attaching your code after I made a few corrections. I've explained each modification with a comment that starts with "MOD:". Let me know if any of them is unclear. Essentially, the problem you were having is that you were freeing some of the elements more than once, and others (mainly the lists, but also an element or two) were not being freed at all. The comments should explain it.
I checked the help for CVIXMLCopyElement, both in the function panel, and in the external help, and I didn't find a problem with the number of parameters. The function expects five parameters:
CVIXMLCopyElement (CVIXMLElement srcElem, int copyChildElements,
CVIXMLElement destParent, int index, CVIXMLElement *destElem);
What do you see in the help?
As far as the beta is concerned, yes it does follow (roughly) an annual cycle, but currently there is an active beta program, so at this time of the year you should receive a reply within a day or two (note the beta announcement that was posted here in the forum just last week). To answer your last question, if you use the beta, you can get a report of which elements were not cleanly removed.
An example for how to deallocate the list that you get from CVIXMLFindElements can be found in the function help itself. Look at the help for the last parameter.
Luis
08-15-2008 05:39 AM
Hi Luis,
first of THANKS VERY MUCH. I got it running - finally.
One of your comments rang a bell: I didn´t realize that i should not have to dispose an xml element which was part of a list already being removed. I removed that element explicitely which caused the hell of a number of dynamic memory errors which lead me to not free enough elements finally.
CVIXMLCopyElement
CVIXMLStatus CVIXMLCopyElement (CVIXMLElement element, int copyChildren, CVIXMLElement parentElement);
Thats what the internal help of my version (8.5) returns - and i think we agree - thats kind of wrong).
kind of follow up question: i cannot find any example for writing xml files.
I feel quiter stupid, but i don´t understand how to add a new element with cvixmlnewelelment, as it refers to a parent element i do not have (i´m using an empty list).
Thanks again for your great help!
