LabWindows/CVI
why does mktime provide different result?
I'm using exactly the same data to initialize 2 struct tm's, but the result given by mktime is different on each case.
Code section:
  start.tm_year = sYear;
  start.tm_mon = sMonth - 1;
  start.tm_mday = sDay;
  start.tm_hour = sHour;
  start.tm_min = sMinute;
  start.tm_sec = 0;
  start_t = mktime(&start);
  stop.tm_year = sYear;
  stop.tm_mon = sMonth - 1;
  stop.tm_mday = sDay;
  stop.tm_hour = sHour;
  stop.tm_min = sMinute;
  stop.tm_sec = 0;
  stop_t = mktime(&stop);
Result:
(2,838 Views)
If I look in the manual, there is a field for daylight saving. If you did not initialize it, it can be anything. And the difference would be typical 1 hour.
Succes, Jos
(2,836 Views)
