LabWindows/CVI
Error -2147418113 when connecting with SQL toolkit
I have no trouble connecting with DBConnect( ) to an Access database.  However, when I try to connect to an Oracle database (Oracle73 driver), I get error -2147418113 "Catastrophic failure".  Any ideas?  Thanks.
(5,479 Views)
Hi Gris,
This seems to be a relatively common error when connecting to SQL databases and is not necessarily related to LabWindows/CVI. The following are several third party resources that I hope you will find helpful in your troubleshooting:
Microsoft Support 1
Microsoft Support 2
Microsoft Support 3
There is one KnowledgeBase referring to this error when expereinced in our LabVIEW Database Connectivity that you may also find helpful:
Receiving Error -2147418113 "Catastrophic Failure in xxx.vi" When Using Database Connectivity Toolki...
I hope this helps!
Jackie
DAQ Product Marketing Engineer
(5,465 Views)
