LabWindows/CVI
viscanf() function using question
I write a function (not main function) I want to create this function as a dll document,when teststand use dll and run it .
the question is I want to use this function get result from instrument,But I don't confirm viscanf is right?
ViStatus _VI_FUNC Get_Frequency (ViSession instrSession, ViPReal64 frequency,ViString freqCommand)
   ViStatus status = VI_SUCCESS;
    ViChar   buf[BUFFER_SIZE];
 ViInt32  retCnt;
 if(status=viPrintf(instrSession,"freqComamnd\n")<0)
     return MT8820B_status;
 if(status=viPrintf(instrSession,"*OPC?\n")<0)
 if(=viScanf(instrSession, "f%",&frequency)<0)
     return status
I use viscanf() like that,it's right? thank you
(4,394 Views)
ViPReal64 frequency is allready  a pointer to a floating point number. So you don't need the & operator in the call of  viScanf.
It should read :
if(status =viScanf(instrSession, "f%",frequency)<0)
     return status ;
(4,363 Views)
that's means if I use a ViInt32 data type ,I must use &  . thank you !
(4,357 Views)
Accepted by sean_tan
You must  use a pointer to ViReal64 inside your function Get_Frequency () to make use of  it as an output parameter.   When you call  Get_Frequency()  you can use the & operator there with frequency being a ViReal64 ( not a ViInt32 ) :
Get_Frequency (instrSession, &frequency, freqCommand )
(4,352 Views)
