LabWindows/CVI
utility library error string function?
I've been working on an Error Handler library, culled mostly from these wonderful fora (Roberto!).  I can't seem to find an error code string generator for the functions in the Utiltiy Library though (in particular, functions like RenameFile, CopyFile, GetDir, SetDir, MakeDir, all the file i/o functions).
Most of those make mention to negative error types with some plain text explanations.  But there's no mention of a nice code-to-string converter function, as there is in other libraries.  For instance, for the RS232 library, there is GetRS232ErrorString.  For the Formatting & I/O library, there is GetFmtIOErrorString.
Am I not seeing it somewhere?  Inside the Utility library, there is a multithreading error code function called CmtGetErrorMessage.
(4,976 Views)
Greetings,
There doesn't seem to be a function in the Utility library just like the other ones you mentioned, but the following article may help in handling the errors yourself:
http://zone.ni.com/reference/en-XX/help/370051Y-01/cvi/programmerref/errorchecking/
And for the error codes themselves, you can search by function:
http://zone.ni.com/reference/en-XX/help/370051Y-01/cvi/libref/cviutility_library_function_tree/
Brandon V.
Applications Engineer
(4,944 Views)
Darn!  I was afraid of that, just from my own exploration.  I'm somewhat surprised.  Seems like a big omission, given that most of the other libraries have their own string errorCode decoder.
Oh well, I'll make my own.  Thanks.
(4,923 Views)
Accepted by ElectroLund
You're right: the Urility Library does not incorporate a function that translates error codes to a meaningful text. I suppose this is due to the fact that error codes partly overlap, so a unique function could not be used.
Just as an example, error -1 means File not found in almost all file I/O library functions, but it translates to No files found matching the search criteria in GetFirstFile () , to No more files in GetNextFiles () and Invalid Parameters in MakePathname ().
Another example: error -2 means GetFirstFile must be called before if returned by GetNextFile (), and Resulting pathname too long if returned by MakePathname ().
And this considering only File I/O section of the library!
While developing my own toolbox of utilities, I have created the following function, which I know is far from perfect and covers only file I/O functions:
char * CVIFUNC GetULibFileIOErrMsg (int error)
// Messages associated to error codes returned by functions in File Utilities class in Utility Library
	switch (error) {
		case 0:	return "Success";
		case -1:	return "One of the path component not found";
		case -2:	return "Resulting pathname longer than 260 chars";
		case -3:	return "General I/O error occurred";
		case -4:	return "Insufficient memory to complete operation";
		case -5:	return "Invalid path";
		case -6:	return "Access denied";
		case -7:	return "Specified path is a directory, not a file";
		case -8:	return "Disk is full";
		case -9:	return "New file already exists";
		default:	return "Unknown error";
	return NULL;
Proud to use LW/CVI from 3.1 on.
My contributions to the Developer Community
________________________________________
If I have helped you, why not giving me a kudos?
(4,918 Views)
