LabWindows/CVI
using .OCX file
I use with LabWindows/CVI v7.1 and try to using with logitec .OCX file .
Wen I run the "Creat activX controller..." I don't see the .OCX file after i serch them with Browse button.
The .OCX file type isn't show in "files of type" window.
pleas leat my know how I can fined and use with .OCX file
thanks in advance
Yaki Fleishman
(3,810 Views)
To confirm wether you have regsitered the activex control or not. I think that would be the reason why it have not display in the list, but I am not sure.
(3,802 Views)
Hello
Make sure your OCX is registered on the system. You can do that by using opening up the command prompt window, and typing in regsvr32 and the full path to the ocx.
So it would look like this, if the ocx is under the windows system32 folder and was called test.ocx
regsvr32 c:\windows\system32\test.ocx
You can browse for the ocx by yourself, choosing to view all files. Once you select the OCX in the file dialog, CVI will automatically register it for you if it was not registered in the first place.
Hope this helps
Bilal Durrani
NI
(3,789 Views)
